removing spoiler
just a quick query guys, i have a gti spoiler on my 6n and want to remove it, it hasnt had holes drilled it but it seems to be glued on with some sort of black material ( bought it like that) just wandering if anyone could give me any pointers on removing both the spoiler and black glue without damaging paintwork, thanks alot :)
  • Views 983
By the sounds of it its the same sorta stuff thats used on the side bump strips. Best way I've found is heat gun/hairdrier for a bit until it starts going tacky and then GENTLY start peeling it off. Dont hold the heat gun in the same place too long though else you could burn the paint, keep the gun moving and heat the entire length gradually, then eventually the whole length will be hot enough to get off (hopefully in one go!) If there are any tacky bits left then get the white spirit out! Wash the white spirit off straight after though with soapy water and rinse with clean water as it can dry paint out sometimes.
Hope that helps! :)
Yeah as above, some patience and a hairdrier or heat gun..be carefull though take you're time!
Or you can use the dentol floss trick as well 8-)
