Car pulling on motorway when releasing gas pedal
hi all,
i have a problem, i have taken the car on the motorway the other day and while on the M"% i have release the gas pedal and, the car tried to move on the left a bit( sepeed was 65) i have since changed the tyres and did the tracking but it still doing it.
the guy at the tyre place told me that might be the rear bushing.
do any of you have an idea\/
and does any of you how much might cost to change the rear bushing?
thank you in advance
Chicco :-(
  • Views 1.2k
it could be a bottem arm mate with a lil bend in or somethink
lower arm mate i had the same on my breadvan, cheap enough though :-)
What car is it?
hi hayesey
it is a polo 6n 1998 1.4 cl 8v
Edited by chicco
just had same problem on my 6n, lower arm bush deteriorated to check leave the handbrake on and use a wheel brace to tighten one of the bolts, if the wheel rocks foward it means the bush is totalled 8-)
buy a balljoint splitter before you attempt this, I've had a rather bad day due to lacking one lol
thank you all for the reply,
i have tried and yes the wheel on the passanger side rocks
i will bring the car to the garage.
i can confirm that it was the lower arm bushes.
thank you for all your responses
Chicco
