BROWN Mk2 Dashboard
Only been looking for 3 years, and since my black dash is out, would be nice to put a brown one back in to match the rest of the interior.
  • Replies 9
  • Views 1.5k
Do you have the glove box for your current one? I'v got a brown one up for grabs, just no glove box. You looking for the clocks too?
bump
still looking
Glove boxes are always black, same with the centre console and the piece with the two cubby holes under the steering wheel
bump
How about paint as a temp fix :o
hmm, what kind of paint tho? surely it would just flake/wear off?
Plastic primer then you can use any aresol (Metal/Plastic etc etc)
Or you could use plastic paint straight onto but i doubt it would be as good. Scotch paper would be best to rough it up a bit and just make sure its really clean before you paint. Get some piccys up if you do this (Y)
