Polo 1.4 16v AFH Low Boost Turbo setup
Hi,
Item: Low boost Turbo setup which fits a 1.4 16v AFH engine.
Condition of Item: Everything is used (Apart from De-compression plate & Boost controller)
What it will Fit: 1.4 16V AFH Engine
What's included:
- Intercooler
- Intercooler Boost pipe
- Manifold (Use standard manifold and this is a kind of adaptor which joins where the manifold splits into 2)
- Downpipe
- T2 Turbo (Slightist bit of Play in the shaft, nothing major)
- Boost Controller with Vacuum hose (Anodised in Dark Red)
- De-compression Plate with a Special Sealant it came with (From Ferriday Engineering in Wales)
- Turbo Air Filter
- Dump Valve
- Oil Return Line
It comes with all the relevant hoses/pipes & Clips which are needed.
In order to fit this to your car you would require a Management system (Piggyback is fine & cheaper) but a standalone would definetely be better.
Should be run at approx 0.8 bar of boost.
Price: I'm looking for around £300.00 ONO
Postage & Packaging: Postage will be around 20quid, in a big box and quite heavy.
Pictures:
I have not put this on my car and has just been sat under my bed in the box since I bought it as I decided to go a different route with my car (Engine conversion) instead hence the sale.
I can send better Pictures on request if you send me your email.
Any questions drop me a PM or comment and I'll get back to you as soon as I can.
Harry
Note: I am willing to Part Ex with a 4-2-1 Stainless Steel Manifold and cash my way :-)
Edited by haz911
  • Views 816
what sort of power gains do you get from this?
reckon it will fit an arosa sport 1.4 16v? same engine pretty much??
Well the guy I bought it off ran it on his polo 6n at approx 125-130bhp and he only had a chipped ECU. If you had a piggyback or standalone system I would imagine maybe 150ish with right map etc. Probably more if you up the fuel pressure as well.
When I bought this I was also told it would for a Seat 1.4 16v but not sure what model. You would have to double check the manifolds are the same so the adaptor fits.
Harry
hello there mate, whats best price you can do for me on this? thanks x
Sorry mate its now sold.
harry
