I've got a dilema...
EDIT
Edited by Sicx
  • Views 901
99000 miles is f**k all!
if its serviced regularly and looked after you should see another 40000 easily. even then a 1 litre is not going to cost the earth to replace if it does go bang
get modding!!!
There's nothing more important than maintenance. You've been told bollocks because the engine should be good for another 400,000 miles let alone 40,000 if looked after properly and serviced properly. Which they never are.
There's something wrong with your engine,and 'its just old' are the words of a novice you dont want working on your car. Its probably just worn tappets (obviously you'll have done an oil change already,so it wont be the old degraded oil),could be a worn cam but whatever,it can be fixed.
