Full respray
As my valver will be sat on the drive for a while and i would like to weld things and plastic weld the bumpers I've decided to do a respray.
I made a topic a few months back about starting costs.
I've decided i would go buy a 50 lr compressor and all the gear.
I'm thinking about going Bright orange , or candy red?
Has anyone here got pictures AND words of wisdom (advice) about spraying it your self?
Good/Bad experiences reasons to and not to spray your self
I was going to heat the garage up , take as many pannels off as i could and spray it over.
Knowing that i can spray the whole thing will mean that i can do the bodywork the way i want it too, and i can fill and sort issues out with it.
Pic
I've just gone out and brought a load of tools also , Next on the list is a mig welder and the compresser and much more!
Edited by mpsheen
  • Views 1.3k
best bit of advise I've ever been told. "If you don't put enough on don't worry as you can always put more on, but if you put too much on you can't take it back off" that is how you get runs lol.
A 50 ltr compressor would be ok but a 100ltr would be more manly for the job as a 50ltr will run out of puff very quickly.
preperation is the key to sucess. Bad prep work will result in a bad finished product.
take your time. I rushed mine as I only had a day to do it, now I wish I had spent a little longer but oh well, I have high standards lol
Good luck
Very Nice
I've brought this car do to as a project , so everything i'll do will be done my my self. Maybe a bit of help when needed ie - 2 man job ect.
Is it tough to get a nice finish?
I've only ever eattle canned bits and bobs before
After seeing that i want to now go buy a compressor , go do a whole load of welding and spray it then do all the mechanics!
Was there any points during spraying where things would screw up?
EDIT:
Just seen a 3hp 100liter compressor new for £165 here , off some one?
Edited by mpsheen
this was my efforts btw
http://www.clubpolo.co.uk/forum/index.php?...=218272&hl=
You want to get yourself an inline air pressure regulator and set the pressure of your gun to 2bar.
If you choose a solid colour it will be cheaper as you can get 2k solvent based paint and don't need to base coat and laquer.
You need to watch out for edges and swage lines as this is where you will get runs. If you don't put enough on you will get dry patches.
You will need to mop it afterwards but I'm sure you will be happy with the end results. All children are pretty to their parents :lol:
Put lots of THIN coats on. As mentioned above, prep is key. Any minor inperfections before spraying will be 100 times more noticeable after spraying. Go through the grades of wet and dry ending in sanding everything with 1200 wet and dry (wet obviously or the paper will load up). Make sure you wipe over with pre paint wipes before spraying anything, this will get all traces of oil and grease off. Make sure you cover every single mm with the wipe. Spray primer in thin coats (about half hour between coats) The more the better at this stage to get a good coverage. Flat this back again with 1200 wet and dry. Pre paint wipe again. Spray colour. Make sure these are really thin coats. You want to build the colour over the coats not get a solid coat each time. This will help prevent runs and also patchy results. If its a metallic colour put a 'mist' coat over last. Basically spray from further than usual and move the gun faster. This will really bring out the metallic. If its a solid colour then flat whole car down with 1200 again, really lightly though otherwise you'll cut the paint. Then buff up with a cutting paste and buffing pad. If its metallic then spray laquer coats (again real thin as laquer is generally pretty runny) Then flat with 1200 and buff.
DO NOT SAND PRIMER PAINT OR LAQUER USING A BLOCK!! YOU WILL CUT THE PAINT IF YOU DO THIS. USE YOUR HAND BUT MAKE SURE ITS FLAT, DO NOT USE JUST YOUR FINGERTIPS!!! MAKE SURE THE PAPER IS CONSTANTLY WET, YOU CAN NEVER USE TOO MUCH WATER WITH 1200 GRIT!!
If the gun is set up right you should have no problems. If it isnt then it will be a nightmare!! Results will be patchy, uneven etc. Always check the spray pattern and pressure on a spare board/wall/person before spraying onto the car!
Key to spraying and getting good results is BE SMOOTH!! At the end of panels flick the gun away, when you change direction the gun will be stationary for a minute second which can lead to runs/excess paint build up. If you flick it as you get to the end of a panel and you're changing direction (basically flick the gun as if there's an extra 12" of panel there, difficult to describe sorry!) Then it changes direction off of the panel! Practise this movement before you put paint in the gun as it feels really odd at first!
Hope this helps!! :)
Edited by dansharpy
Thanks for the input!
buy or lend from library a book called classic car restoration by lindsey porter, published by haynes.
it is amazing and will really help
