Leak in Mk3
My mk3 has sprung a leak from somewhere and I cannot find the source for the life of me.
Its happening in the passenger footwell and its dripping from directly above the bonnet pull. It only happens when I'm driving so I'm thinking it's the water spraying up from the road into the wheel arch. I took the arch lining off and sprayed a hosepipe all around to try and find where it is but no luck :(
Anyone had this happen or any ideas where it could be from?
  • Views 850
door seals?
Check where the wiring loom enters the engine bay beside the fuse box. water tends to gather round there and if the rubber gaitors aren't over the loom/fusebox properly it can seep through and down the footwell.
Failing that check that area for corosion. The battery tray always corrodes on mk3's so I'm assuming the other side will be affected in the same way.
Edit: the bonnet pull also comes out in the same place so that might be worth checking.
Edited by Guinnane
Hmm it could be door seals, but wouldn't that leak everytime it rains or got wet whether I'm driving or not?
Same with the wiring loom really, also I sprayed some water into that part of the scuttle tray with the fusebox in and there was no leak at all.
Edited by deanopolo
Take the lower glove box off, I think it's 5 screws and that will give you a better look at things.
