Painting 2k in crap weather!
Ok so I have all the gear and I can & have painted with 2k before etc but only in summer coincidently and just wondered will 2k dry well enough in this weather? (bout 5 degrees and pissing it down?) I will be painting in my storage container so it will obviously be abit warmer!
Any advice would be great cheers!
  • Views 1.7k
use a faster activator/hardener
i've just painted some bumpers today in my unit with only a tiny heater on and used a fast acting hardener
It will take a while in this weather for the solvents to evaporate but it will dry. However I think you may get problems with the finish. Due to the moisture in the air reacting with the paint. Can't you get some heaters to warm it up in there first?
Are you looking at doing a full respray?
I could get some heat in there but it could prove tricky! sorry I should have said in first place I will be using fast activator, that's what I was thinking about moist air and paint not mixing well!
Oh and I'm painting my bbs splits!
Edited by Pepe
2k will be fine, its when you start doing clear over base that you get problems with moisture and the clear not mixing too well
i would use anti-bloom thinners, for extra piece of mind
