KR 16v gti parts whole engine split
Really needing some space at the moment so need to get rid of these bits, was in the progress of doing a rebuild on this engine but i then got a polo coupe s so wont need it!
Parts are:
Cams and chain good condition no dodgy wear marks will get pics soon £25
42mm Inlet manifold, got both parts the main part has been bead blasted and small section has one of the injector housings broken £20
Bead blasted rocker cover with oil cap £15
Pistons, rods, pins and caps (2 pistons have been cleaned up and crack detected can still get the others done for the sale if interested) £20
Bottom end which has been fully degreased and preserved (no crank as it had some bearing problems but bores are fine etc £20
Throttle body £15
Skimmed head done to a very good standard none of the valve seats have been ground but also has been fully degreased £50
More pics on request of everything there, got a whole engine but just listed the main parts so get in contact for other parts.
Text preferably or PM
07775868149
  • Views 254
BUMP
