Kenwood sub, 6x9s leads and JBL 600W amp NEW
Hi
I am selling a Kenwood 12" sub, two 6x9s, JBL 600W amp and a lead set. This is absolutely BRAND NEW and I have not used it at all. Some specs:
* Leads include power leads, black plastic shielding, blue remote control lead (from stereo to amp to turn it on/off), an in-line fuse holder (with fuse) and necessary spades, rubber shields and cable ties.
* Speakers are Kenwood 6x9s (usually put in a parcel shelf or stealth shelf), and are 350W peak power. They come with a length of speaker wire, and are component speakers, with the larger speaker handling bass and middle, and the small tweeter handling the trebles.
* The amp is a JBL GTO 600W peak power amp. It is 4/3/2 channel, so with the speakers included, it'd be best to run it in 3 channel set up, two channels to the 6x9s, and one channel to the subwoofer. As you can see, it has crossovers on the front and rear, with high pass and low pass filters. For example, you could set the crossover to a lowpass, to ensure that only low frequencies below the x-over Hz range get sent to the subwoofer (no point in the subwoofer trying to push out high frequencies it can't play). This is boxed, bagged, with fuses and brand new. Nice clear top means you can see the internal electronics and transistors too.
* The subwoofer is a Kenwood 12" 800W peak sub (no chance of it getting blown up by the amp). As it stands at the moment, it is in the carpetted wooden box and wired into it, ready to be put in the back of your car.
Pickup from Droitwich, near Worcester. Alternatively, I will deliver it for ~£5 anywhere between Worcester and Coventry, as I work in Coventry so I am happy to meet up during the week on the way home (not Sat/Sun).
Brand new, £120. Pictures are available on http://marsh.gibbotronic.com/index.php?p=g#ref34.
PM me if you're interested. Payment by Paypal, I'll let you know the details if you want to buy.
Rich
  • Views 214
Bump!
Bump again! Booming bass waiting for somebody!
