6n rear quarterlight
hi guys,
some tosser broke into my car and smashed rear quarterlight glass,how difficult is this to change?do i have to remove rear door card and rear glass?
tried using the search but only found front quarterlight replacement on the older polos.
thanks in advance.
you will need to remove the door card and rear glass and the main window guide
Edited by tahittiblue
was kind of hopeing i could manage it without removing rear glass.
oh well.
you can do it by just putting the window down but you still need to remove the door card to undo and move the window guide
that sounds not too bad then,ill need to get to the scrappers at the weekend then.
thanks buddy.
