Looking for a guide or how to
I cant find my Haynes manual and my passenger door is jammed shut is there a guise or write up on removing it.
All help would be greatly appreciated.
  • Views 558
It's pretty easy to do, just a few screws.
Take off the cover on the window winder and theres one there,
Take off the cover on the inside door handle, theres two big screws in there, then pull away the handle itself
Then on the side of the door, the side with the latch and lock pin, theres two screws there.
Remove all these, then also unclip the surround for the release handle, it slides off, cant remember which way.
Once the screws are off start at the bottom and try and lift the whole thing abit, to unhook it from the 3 clips at the bottom, you can get your hand in slightly iirc to help take it off the clips, and also the doorcard will flex a little, then once its off these clips pull the whole thing downward.
Then refitting is just the reverse of that. Can be stubborn trying to line things up and hold it all in place though.
