Door not staying open
My driver's door isnt like locking so doesnt stay open at all, whereas the passenger door locks half open and fully open.
What part causes the door to lock? would I need a complete new hinge bit
Edited by getmoregetmint
  • Views 874
there's a bronze bar iirc on a 6n, check that hasn't came off.
it's called a check strap :)
Yeah these can wear out there pretty easy to replace aswell!!
Once, when I had a Corsa, I was in Sheffield and it was windy and the wind blew the door and it broke the thing you're talking about. It didn't acutally break the bar, just the place where it connected to the door/door frame. I put a small bolt through it and it was fine. Compare the two sides and see if you can see the problem.
