Higram the '91 GT
I've decided to go a bit more old skool and picked up a GT last week :)
It's done 75k and is really solid. It has a couple of car park dents, but nothing that can't be sorted. Arches are mint, and the underside is cleeeaan as hell!
Spec:
'91 Polo GT on 75k
4-2-1 stainless manifold
custom stainless decat centre section
Powerflow backbox
Plans:
Hit it with the lowering stick
Stage 3 subframe with uprated gearbox mount
Mk1 GT sidestripes
New wheels ;)
New interior
More powahhh
256mm brake upgrade
Pics:
Got it down to the pit on the night I picked it up. Fitted new tie rod end due to a split boot with the help of Saf and Ad :thumbsup:
76722_10150314556130384_606115383_156388
Got a lambda boss welded into the manifold
74830_10150314556175384_606115383_156388
75176_10150314556220384_606115383_156388
72727_10150314556295384_606115383_156388
Fitted my OMP 300mm wheel:
76022_10150314556195384_606115383_156388
So yeah, plans are to sort out the bodywork and chassis over winter/spring, and then sort out the power next summer ;)
Also, my bike carbed 6n is for sale at the moment. For sale thread here:
http://www.clubpolo.co.uk/forum/index.php?showtopic=219224
Edited by tezmc
  • Replies 52
  • Views 10.4k
HI6RAM FTMFW!
cant wait to see it with the new rimmage, subbie and lowered!
Sooo.... after 10 days of waiting, this finally turned up this morning:
154894_10150338549760384_606115383_15999
Fitting tomorrow :) Also got some Mk1 GT sidestripes to go on, 256mm brake conversion and a Stage 3 PPS subframe on its way :ninja:
woop woop!
this thing sounds mental i must say!
whats with higram as a name O.o?
:lol:
:lol: The original plate was H16 RAM and all the glass is still etched with it. It got taken off a few years back and used as a private plate, so it was reissued with H123 NRU.
Give me his dizzy back :ninja:
o yeah i remeber even looking at the eched glass and noticing the reg was different :lol:
currently not driving atm due insurance costs :( more than welcome to come grab it yourself, or i could take a long walk to ads :lol:
:( I've not seen yours yet either. I'm in no rush for it dude, will just need it at some point :p Seems to be running ok on the current dizzy atm.
Edited by tezmc
Suspension is now on :D
156168_10150340895525384_606115383_16036
Got a bit of an issue with exhaust/road clearance though :( Gonna take a look at that today
76094_10150340895895384_606115383_160365
What drop is that ?
60/40 on an FK kit. The rears are on the middle setting.
My Vectra calipers and carriers are sat ready to be repainted, and am just waiting for my discs and pads to turn up now. Stage 3 subframe is hopefully going on in the new year, then it's time for a couple of trackdays :D
Also, I'll just leave this here :) Should be alright until I get my Steffans finished
Busy weekend ahead I think :)
PPS Stage 3 subframe with uprated rear gearbox mount, and a 256mm brake upgrade using Vectra 16v carriers/calipers along with Mk2 Golf GTi discs. Should give me enough time to bed them in before a track day at Oulton Park at the beginning of February!
Interestingly your frames slightly different to the one stuart built for me, the rear mounts on yours only wrap around the one side where as mine are on both sides (i'll try and find a pic, will make more sense)
Also, you got the right shoulder bolts to go with those callipers? If not you can get them off ebay pretty cheap
Hmm, I'll speak to Saf and see what his is like. We ordered them at the same time so should be identical really. I've not had a look at fitting it yet, does the wrap around bit do anything?
And yeah I've got some high tensile shoulder bolts for the carriers. Just need to get some washers and brake fluid now.
I cant imagine it makes a difference, it braces off the inner part anyway (it just makes it a hell of a lot easier to fit yours too, which is probably the reason he's changed the design)
Also get yourself some rubber boots from ebay or rally deisgn for the rose ball joints and fill them full of grease!
Edited by Renegade440
higram is a spoilt bitch :lol: looking good tez get it all fitted !
:lol: higram is a slag.
Getting my steffans back from the refurbers on Friday as well :ninja: New rubber should be arriving today
jus seen the sub frames your gonna be puttin on, looks mint dude!
jus woundering where could i get 1 from n how much are they roughly?
yeh mine is the same man, tez and dan. he hasnt mentioned to me, but your probably right dan about the reasoning for changing the design, it will make an already easy to fit subby, even easier!
i asked about dust boots and stuart is going to send us some over. I'm not sure if you would want to fill them full of grease though, i always thought they are pre sealed full of some type of grease or bearing compound, and that they are for life, so i think the dust jackets will be sufficient on thier own.
ill know for sure at the weekend when i replace the old subframe for a new one at the weekend, as that one has been fitted for around 3-4 years ago, is running dust jackets and still handles like the nuts so the rose-joints must still be in good working order. ill let you know if they were greased or not =]
FREAK - thats the correct link above by Tez, price varies slightly if you want an uprated gearbox mount shown in the picture. if you have a few mates that want a subframe too, he can sort you a little discount. you can have it painted pretty much any colour, and type (loads of metallic and special paints) at no extra! really is a top guy is stuart
steffans will look rude as fuck ! in white ? :ninja:;)
shh you're ruining it! haha, yeah in white. they are coming back on tuesday if i get time to pick them up. too much uni work and exams at the minute meant that i didn't get the brakes and subby fitted either :(
Dude what exactly did you use for your brake conversion? Cheers ben
Ben, have a look in the braking section and there's an FAQ on it. Basically though, Vectra calipers, carriers, pads and flexi hoses with Mk2 Golf GTi 16v discs. You'll need some shoulder bolts as well.
Just picked these back up from the refurbers. They've done an amazing job considering the state of them when I dropped them off!
179433_10150385304005384_606115383_16896
Can't wait to wax them up and get them on :ninja:
cheers dude seen the FAQ yesterday but there seems to be confusion on the flexi hoses lol do i use the vetra ones or the standard ones cheers ben
