Mk2 Bread Van vs Mk2F Saloon
I killed my Breadvan in style - straigt into the back of a merc. It still works but won't pass it's MOT next week because of the dented bits. I've found a Mk2F saloon.
To anyone that has driven both, just to get some idea, how different does this car drive? Both are 1043cc 4 speeds, the MK2F is single point injected.
Want to know what to look out for in terms of differences? I'm guessing the brakes are a lot better!
Yes,you dont have to pay as much attention to what you're doing,though the higher stereo placement will allow you to do so,but otherwise it should feel quite the same.
Saloons sound slightly more refined. No rear wiper means you may want to use your mirrors more,particularly if you intend on practicing random late hard braking..
Brakes and suspension are utterly the same. Biasically, it's a facelifted version of the same car. Saloons are rarer than any other shape in mk3 (because no one ever wanted them), but this means rear end parts are getting hard to find.
Picked it up and your right, it's just like the breadvan, a little more modern feeling. Thanks for the pointers.
..other than the front brakes being really quite different on pre-'86 MK2's, with pressed steel calipers and half-pint pads,and the MK2F from '90 having its brakes power assisted by a servo,which tbh transforms the feel and initial bite.
