Removing front passenger seat from Mk4
Please could someone tell me or send me a link to a guide on how I can remove the front passenger seat from a MK4.
I've had a look on the forums and the web and can't find anything that's clear.
Thanks.
  • Views 1.2k
There is a Allen bolt and nut just under the front of te seat! Undo that, unclip the black plastic trim on the rail (side by handbrake, then slide th seat all the way back! Should come out!
What he said, it really is that easy :)
super easy pal :D same goes for the drivers seat, and the rears come out without unbolting anything!
you'll need a 5mm allen key and a 10mm spanner for the fronts ii i remember correctly!
thanks for helping me out :) this should be pinned
