Mot fail?
Just quick question... is this rust a MOT fail? it's due in soon so want to save the cost before having to put it through to find out
thanks
  • Views 833
Should'nt fail on structual corrosion, but some testers might say it's bodywork in a dangerous condition ie it could harm a pedestrian if they made contact with it!! untill you can do a permanent fix, bend the rusty edges inwards then some expanded alloy mesh behind the panel with P38 filler, sand it smooth and a quick spray of primer should do the trick!!
thanks for the answer! I'll get the filler out and patch it over.
tyre looks close to the limit judging by wear bar indicator too but I am looking on my phone! possibly an advisory. Good luck
