New To VW polo's
Hi,
I am new to the whole polo vw scene and need some advice of prices and specs.
Will proberly see around 2.5k for my current car so would like to spend less than that buying a polo. It needs to be as cheap as possiable to run so i have been looking at the 1.0 versions how much would a decent 2000-2002 think its mrk5 polo cost?
And are the 1.0 lumps any good in terms of parts, fuel, tax
Thanks James
  • Views 879
Hi James
I dont know how old you are and it may be better to get a 1l for insurance but if your looking at an 6n2 as they are generally known on here you may be better off getting the 1.4 75bhp versions.
They can in many cases be about the same or better on fuel than the 1 litre engines as they have a bit more grunt to cope with the wieght of the car better
A decent one will probably set you back about £1500 you may get one cheaper you may not.
Tax is about 120 a year
Insurance is fairly low group wise
Parts are the same as any other vw really but you can get pattern parts fairly easilly
Fuel wise my lupo has the 1.4 lump and i get about 35-45 mpg depending how drive
Common fauls i know of are:
Temperature sensors can fail only about £15ish and easy to change
Pedal boxes are prone to failing you can tell if they have because the clutch pedal will be a lot lower than the break pedal
Electrics can be a bit dodgy especially the window switches
I'm not sure if this is mainly gtis but the gearbox is a bit of a weak spot
Good luck finding one and hopefully that helps a bit
Chris
gearbox is a weak spot in all of them
as is the brake light switch
and the seals around the gearbox
and the gear linkages which results in the gears being a bit all over the place in the gearbox and not lining up properly
ony my one i have also had the engine speed sensor fail but i haven't heard of it happening to anyone else
just had to do my clutch and gearbox on my 6n2 which aint cheap but it still comes in under 2k total cost
Insurance is not a problem with any car really iam 21 and currently driving a 187bhp clio sport. I am looking at moving abroad next year so need somthing cheap and cheerful that will see me through untill then whilst i save up abit. Only reason i looked at the 1.0e is i assumed it would be better on fuel than the 1.4 i need it to do 40+ mpg really is this hard to get?
Most problems that are fairly small like clutchs and sensors are fine as iam a mechanical engineer and have alot of mechanic freinds?
so a 1.0e version is about 1500 quid for a good one but the 1.4 might be just as good on fuel
Thanks alot for the replys
James
