How to replace a front indicator bulb on a Polo 04?
Hi there,
I can't figure out how to change a front indicator bulb on my Polo Twist 2004. I know this sounds an obvious one but the handbook is completely useless and just tells you to take it to a dealer! I bought the bulb from Halfords, opened up the bonnet and thought it would be pretty self explanatory but unlike my old mk3... it ain't! I haven't got a Haynes Manual for this model, I can't see much point as there's only so much tinkering you can do on these newer models! Starting to wish I hadn't got rid of my Polo mk3 now... everything seemed much more straight forward!
If anyone has any idea or knows how to do this then i'd be very grateful if you could run through it or point me in the right direction.
Thanks in advance, Rich.
  • Views 9.1k
Hi Rich, this is taken from ELSAwin
Unscrew turn signal bulb fixture, holding it on, Grip the "arrow" & remove, fitting in reverse
yeah, you twist that about 45 degrees iirc. Anti clockwise, re-fitting is the reverse of removal.
Thanks very much, i'l give that a go on mi' lunch!
managed it in the end... they don't half make it more complicated than it should be! Thanks again.
