Polo 6n2 seat wobble
Hello
I have a polo 6n2 and the damn front seats are wobbling.
Is it a common problem and is there a easy fix?
If not, how on earth am i supposed to remove the front seats! I have been looking at it for few minutes and i cant figure it out :(
  • Views 2.7k
Easy to fix, you need new seat gliders, pieces of plastic that the seat runs along. They're only pennies from VW.
Start by removing the bolt at the front of the seat in the centre (allen key and 10mm spanner)
Then pop off the plastic trims from the seat gutters.
As you've removed the locking nut and bolt (step 1) you can now slide the seat all the way back and out of the seat gutters.
Now that the seat's out of the car, you should be able to see the white plastic glide piece i'm on about, get a couple new ones ordered from VW and you'll notice a massive difference :)
Awesome! Thanks alot :D
