Engine cowling.
So i've seen some polo's with the 'newer' engine cowling over the top, i have a 94 mk3 and I've seen them fitted. Currently looking at some on ebay and what not, what cover is most commonly used?
Jakeeeeeeeee
  • Replies 9
  • Views 1.6k
I think it is a 6n2 1.0l one, a mate of mine had it on his gt, does look tidy just take the 1.0l badge off
I'm gunna ask a question on this how do you fit it on?? as i have been wondering for ageis
from a 8v 6n
You need the 6n engine lifting brackets to get one to fit :)
Be warned though, there a pain. You have to remove it to do the simplest of things.... check your oil :mad:
Do you mean this type..?
If so,there are two brackets,one for the left mount and one for the two right mounts.
The engine above is a 1.6 (well,was..) but its the same but for the cambelt cover and camshaft cover both having the correct shape/profile to fit snug. The engine pictured also has bike carbs in place of the air box,the GT engine would of course have the elbow-type throttle body intake instead.
I usually ran it - as you can see in the pic,it doesn't get in the way of anything.
Nice bay mikey. The engine mounts look a bit tired, losing a couple of ponies there :p
Could you not get a later dipstick and dipstick housing (or just the collar) to raise it up?
The engine's long melted down,its probably a pallet of bath taps by now. Engine mount was healthy enough,just looked old.
The 6n dipstick tube should fit the GT engine,but there are different lengths and different length sticks too. Obviously getting a pair that'll read accurately on that engine is important,or just bracket the existing one further out - its fine to bend them a little,they dont kink unless you're daft.
Yess! Thats the one been looking on how to fit them for ages, i assume you can just get them from the breakers or whatever?
And the engine lifting brackets should come with it?
I actually have one of these sitting in my garage- has the cowling, the plastic tabs that cover the bolts, the bolts, the brackets that fit it too.
PM me if you want it...wanting £30 for it delivered and i also have a 6N 1ltr rocker cover as pictured above which i want £15 for and has the bolts too. :unibrow:
It was original to that engine,which was from a '98 6n 1.6.
If removing it from a car in the breakers,you remove the three plastic caps,then the three bolts,then the cover.
Then you'll see the two brackets each bolted to the head,you remove those via the one M8 bolt on the left one and two M8 bolts on the right one. I know the right one is a straight swap,not sure if the left one will bolt straight to the GT head without modification but it should do or be easy to adapt because there is an M8 thread there for it on the older engine - they're a straight swap for the ones already on your engine.
