Project : Rims
As some of you probably know, I do like wheels! so i've bought yet another set to do some work on! This time some classic 90's rims, Azev A's in 16x7.5j Flavour.
I'll start off with a run down of some of my previous refurb attempts.
First set of wheels I refurbed with my dad a few years ago now, had come off a fabia VRS that had been on its side...
Done using only rattle cans! Not bad for our first attempt really!
Then I did a set of Mondeo ST24 Alloys for my mate's fiesta. (Yes I know they're fugly, but he liked them)
Then stripped and polished a set of TT comps, inserts painted grey. (again with the help of my dad!)
Me and my mate burna did a quick refurb on these wheels that cost him only £30!
Then I bought my first set of BBS! Painted by myself.
DIY Tyre fitting on my Borbet A's... lol
Brock B1's, the lips on these were wrecked :(
Didn't know where I wanted to go with these, so grey centre with holographic metal flake and polished lip!
Then went for silver and flake
Then Enter 2nd set of BBS, RX2's
Split and polished
Bolts too!
Centres Painted
Back together with new caps
Remotec Alulines, silver lips and Audi Daytona grey centres. Refurbed for my lass.
BBS RS, Refurbed for my brother, Red centres with red metal flake, polished dishes & bolts (FOR SALE)
Also had these for a while, need lacquer peel sorting, not sure what to do with them... something special, it'll come to me eventually! (there are 4)
Brings us up to date with these... the latest project, Azev A's
Not sure where i'm going with them yet... need some centre cap stickers, was thinking either a high metallic silver or high metallic grey... not sure tbh!
  • Replies 27
  • Views 6.6k
I knew these would be around again soon, second person (i know of) to let on about their 90's acceptance and get the Azevs out. If you need any spares, I know a man with at least 2 sat in hedges/under cars (JVWA, theberton).
I really love those Remotech Alu's. You still got em?
Edited by randombadger69
Ho you refurbing the curbs and missing chunks are you using liquid metal? Filler? Only problem is that they can never be polished up unless you weld them?
But great work mate non the less! almost perfection whatever your doing lol
Yes yes, Tig welding and smoothing back would be the way if you wanted to polish. My local powdercoaters use Isopon metalic (Alu-based filler) to fill minor curbage. Apparently it "shrinks" a bit in the oven, but if you were spraying this wouldn't be a problem.
fuck how many sets? top work work though pal
lol, i've owned another 3/4 sets that i've not got pictures of!
I see you like to keep busy :lol:
Keep up the good work :thumbsup:
Great job man!
Do you refurb just for pleasure or do you do it for money too? I have some Audi wheels to be mirror polished. :D
Great job man!
Probably do it for gay sex???? hes pretty cheap is panda ;D lol !!!!!!!!!
lol sean's just saying that because it's the currency he's used to dealing in... lol.
It depends really, I quite enjoy seeing the end result :)
good work. now how do I got about getting metal from just bare metal to mirror polished?
I want to polish up some dishs.
Is it possible for you to give me some quick steps, and equipment needed?
Muchas gracias
well tbh if you're polishing dishes you're probably best off doing it by hand, work your way from 800 grit paper to 1500 or 2000 grit (wet) and then use peek metal polish or autosol to bring it to a shine.
Love type A's. And those remotecs are awesome too
Edited by prankstar2003
is that literally it? just keep sanding and sanding getting higher then finish off with a metal polish?
if the surfaces are flat then ideally a block is good to avoid ripples!
dont rush the polishing and dont skip through the grades quick....the sore fingers will be worth the end result!
all crap if I'm honest :lol:
This inspires me to pull my finger out and refurb my Rj's.. :nod:
get them done :) its really worthwhile when you see the end result.
Thanks for the comments Max. Especially after I fucked about with your name change and that.
Project Azev's are now free of tyres, been concentrating on other stuff recently (my recaro's) so i'm gonna crack on with these now the recaro's are sorted :)
How did you get a mint polished finish on the dishes on the brocks? As you said they were fucked? Have the same problem :)
I basically used a DA with an 80 disk on it and shaved off the lip, for example on the azev's, all the damage is limited to this extra lip, so I just shaved it off on the brocks.
One rubbed down, one skimmed
Tonight I've managed to get 2 wheels sorted ready for primer, gonna do the other 2 and the centre caps tomorrow before paint... Although i'm torn between two colours.
Peugeot Phoenix Gold
Audi Daytona Grey
Audi Daytona Grey won
