6n2 Dash Conversion 6n
Hi.
I'm Getting A 6n2 Dash For My 6n As I Think Look Alot Nicer And Would Set The Interior Off Quite Well.
Apart From Door Cards & The Essentials Is There Any Thing Else I Should Need E.G. Wiring .....
JB
  • Replies 9
  • Views 1.8k
Your going to need to chop and splice up the existing 6n loom to work with the 6n2 dash mate.
Is It Not Possible To Take The Loom From The 6n2 ??
As I Can Take Any Thing I Need To Make It Work From It
J
you can put the whole 6n2 loom in if you'd like, depends which way is easier for you and what year/spec the car is.
I've done it to mine, it's the only fully working one in the UK... lol!
how hard is it to swap over the loom ??
or how hard is it to splice the wiring. e.g is it just extending the wiring to reach to the new switch locations
yeh but can you use the 6n2 loom on the 6n engine????
or if its in 2 parts would the engine loom attach to the 6n2 loom correctly???
things youll need to know before progressing....or just treat it as a project and have a go!!
Well I'm gonna be doing it soon but I'm using a lupo engine and loom with a 6n2 dash so its all plug and play, I'm gonna take out the whole 6n loom and swap it all over
I Was planning a polo gti lump with loom.
so u think i should wait till i get an engine and take the whole loom with it ?
personally yes...but if you can get all the parts pretty cheap now...then get them and stock pile them!!! but why make a job harder to do when you dont have too....also no point chopping plugs if your gonna need them at a later date!
Just do it all at once, more of a GTI re-shell into your 6n.
