new clocks and speedo still doesn't work
just put a differet set of clock in the polo and the speedo still doesn't work, what else could it be.
when not connected the speedo cable end turns when moving so the cable is not broken.
need bit of help with this one.
  • Replies 8
  • Views 1.3k
It may be worth testing the speedo cable with a bit of pressure on the cable inner (pinch with your fingers?), as when the clocks are fitted there will be a little force applied to the cable resisting it turning as the clocks turn. It could be that the cable is broken but will turn ok when there is no resistance on it.
cheers, ill try that one now.
The speedo also needs power to run, have you checked your fuses, just in case?
i thought that they were just cable operated?
i changed a few of my fuses when i stopped driving the car but will have a buzz.
I found out by accident that if you turn the ignition off on a mk2 while moving, the speedo drops to zero. We had a dodgy ignition switch on ours that was killing power.
ok cool, ill check through all my fises etc tomoz, bit late and cold now. will update tomoz if its helped or not with both.
Right, i have checked fuses, put pressure on speedo cable whilst moving and still goes round strong.
I dont know what it could be, if someone could help that would be great.
Cheers Liam
Any suggestions?
