cylinder head torque settings
does any body have the camshaft bearing cap torque settings and the cylinder head bolts torque settings for a 1.0 litre polo with the aer engine any help much appreciated
  • Views 7.4k
New head bolts required!! torque to 30Nm then +90deg, then +90deg
Cam carrier caps 6Nm then +90deg
Head bolts are 40Nm, 60Nm and then 180 degrees ;)
Edit; mis-read- wrong engine! This fella above is correct^^
Edited by Phataz1
