window regulator glass clips 6n/6n2/ibiza
window regulator glass clips (there are 2, but i couldnt find the other at the time i took the pic, i have found it again though!)
these are the little clips that hold the glass to the window regulator. They are in perfect condition and work fine. ideal if your regulator has got busted clips (pretty common problem on mk4s) you cant buy the clips from vag, they instead, insist you replace the whole regulator for £££££.
The clips were removed from my 5 door ibiza, but it shares the same window regulator as the 5 door 6n/6n2 polo. I dont know if the clips are the same on the 3 door models, so cant comment as to whether these will fit or not
£5 posted
  • Views 268
up
