MK3 Headlinings
I have been told that to remove the headlining from a mk3 you have to take the windscreen out.
So is there anyway of changing or tidying it up abit without having to take the windscreen out?
Would it be possible to buy some fabric and cut it to size then stick it onto the existing headlining?
anyone tried it?
I just took the headlining out of my mk2 and had to remove the windscreen, rear quarters and alld the rubber linings round the door, sunroof etc. It was a bit of a chore but I'm guessing not half as much as its gonna be putting it back in!
What's wrong with your headlining at the moment? If you just wanted to clean it and repair a couple of tears I should think you coul easily manage that in the car, anything else and it might be worth removing it.
I don't think I would try sticking material to the headlining as it is sort of suspended and has a particular shape. Might end up looking a bit whack.
Bit old and dirty really and just want to make it a bit nicer!
Shame as i would like to buy some nice fabric but i think you're right sticking onto the original would look wack.
Btw did you remove the screen yourself? if so hard job?
I'm sure you will be able to get some sort of vinyl upholstery cleaner which should have it lookin ship shape in no time!
I did take the screen out myself and yeah to be honest it was very easy. I had practice in the form of the rear quarters though.. one of which broke :( it was my own fault for trying to lever it out with a screwdriver like a retard though :lol:
The technique I used when I succeeded was (under the advice of someone on here or polo3..) was to use a couple of screwdrivers and gently fold the rubber on the inside of the screen over the lip of the frame, it will make sense if you try it, and then as you ease more and more of the seal over the lip it will start to come loose and eventually just come out.
I think ill go with getting some upholstery cleaner, wouldn't be worth the time of taking the screen and the rear quarters out just to clean it.
Thanks for the advice.
