remap and advice
Hi Guys,
I'm collecting my gt tdi on sunday and the guy told me that the chip for the remap can be taken in and out....So turning it back to standard or remapped! I thought a remap wouldnt be that easy to change?? Am I being special or is that standard? Also it seems the water pump wasnt changed with the cambelt, is that ok?? Its done 79k. Anything else I should be looking out for, its got tax, mot, fsh?
Kind Regards
Will
  • Views 588
I'm guessing this is the 9N GT TDi on the quiestion of the water pump I'm getting my 9N sport TDi next week which has the same engine and the guy selling it to me is going to change my cambelt and i asked about the water pump and he says a lot of these engines had new water pumps fitted inder warranty after only a few years due to a high failure rate so he said when he changes my cambelt he will look at the manufacture date and if from around 2007 he will leave it as it is as it will be the revised design pump which will be fine but is its on the original pump then he will replace it because apparently the orginal ones had problems with the blades inside breaking
Edited by wildman_33
