Which double sided tape for sticking door membrane to door
Hi,
I need to replace the tape that holds my door membrane to the door metalwork because the car leaks when it rains and I've traced the water to leaking out between the door metalwork and the membrane.
The tape seems to be a very sticky double sided tape. After a bit of research it seems it might be "toffee" tape or butyl tape.
Would the following be sufficient?
Toffee tape
Does anyone have any recommendations?
Cheers, Jon
  • Views 1.3k
I ripped all the crap plastic from the doors on my mk3 and replaced it with some thick plastic bags and duct tape! was waterproof for the two years and a bit that I had it.
i use the double sided no more nails tape its holing parts of my car together and works a treat
