Just had some stretch tyres fitted
7.5j and 8j on 185.45.15 sounds like a little air weeping from the 8js
round the edges ? any i dear is it normal ? :oops:
  • Replies 12
  • Views 5.3k
if fitted correctly should hold air with no leaks.
Sounds like they aren't fitted properly. 185/45/15 on a 8J rim isn't much of a stretch so shouldn't leak really. I ran mine for a long time with no issues.
take the wheel off, pour a little water the whole way round the bead, if it bubbles its leaking
Thanks for the advice ill give this a try :)
According the the engineers at Nankang, the 185/45 arent designed to fit to anything wider than 7,5x15, so sometimes this happens. I know 9olo have the same problem
Just double check that the bead is seated correctly. It is not recomended to drive on them if they leak
if you use a bit of soapy water it will show itself more if it is leaking take em back and ask them to re seal it did they bead blast them btw ???
bead blast
?? I'm a tyer noob
Bead blaster is basically a big tank that holds air. For example ours holds around 150PSI. Has a valve on the front which you open and it releases the air. If you do it into a tyre it makes it pop the tyre onto the rim.
nah dident use that gun thing they just put some sealant and blow them up with the normal compressor :/
Frode, the 185/45's are fine on a 8.5", it's the 165/45 conti's on the 8" that i have issues with.
185/45/15 on 8.5x15"
oooups, sorry, must be getting old :D
Oh yeah, thats right, I'm old enough be the dad of some of our younger members lol
