185/55/14 on to 8wide wheel?
ok i can get the tyre on but wont blow up whats the best way to get this on cheers rob
heard petrol lighter fluid put sum in and light it
Edited by breadvan rob
  • Views 976
Seat the bead on one side of the wheel. Fill the rim with hair spray. Make sure it remains as a gas inside the tyre and not just spraying straight onto the rubber and going into a liquid. Put the wheel and tyre on a tyre. Get someone to stand on the wheel. Blow torch inside the rim and it should pop straight on.
You may not need someone to stand on the rim if the tyre is pretty close to the rim anyway, but if its not then you will need someone to close the gap a bit.
sound m8 cheers will give it a pop 2morra tar
worked mint m8 also very fun if your into making fire lol cheer pal
Glad it worked and didn't turn you into a human fireball :lol:
lol would of been quite funny me on the news running down the street on fire holding a wheel with the tyre melting off lol
