Remving the rear Door Cards from a 6n2 Polo
i have a polo 6n2 5door and wanna take the door card off in the back, but i dont know how to remove the window winders? hoping someone can help me out on this please?
Thanks.
  • Views 1.7k
There should be a black ring around the winder and you have to pinch it in at a certain point and pull and it should come off.
For the 6n2, on the base of the winder (where it goes into the card), you have to push/lever the part just between the black ring and the winder.
It doesn't look like it will separate, but it does! Once you lever it off, twist it out the way, and there's a screw down the winder..
thanks people helps alot il try it 2moz :) i wanna see what size the speakers are i wanna change them :) do you think it will make much difference if i change them to good ones?
Here Click This ClubPolo Link
Removing 6n2 Door Cards
Its got a couple of pic I've taken to help, should give you a better idea.
Pete.
Pete.
cheers mate :) that will help loads! il do that 2moz, if i change them factory speakers for some aftermarket ones will i notice much difference?
Most likely, I'm still running standard speakers as I cba to change them atm.
okay mate :) u dont happen to know how to take the badge off then boot? as i wanna spray it black and yelllow :)
