mk5 polo dash
hi all , I'm new to this forum.. reason bein is my mate has a polo low as low can be lol and from what i heard she hit a kurb which deployed airbags.. now the question is how easy is it and how to replace the dashboard.. and where is the module for the airbag i guessed that needs replacing aswell .. any help would be apriciated! cheers steve :-D
  • Replies 9
  • Views 2.1k
PM sent
From what i know, the dash is held in by 4 bolts in the bulkhead, then various screws. The clocks will have to come out, too. :/
The module is behind center console; if you take the side vent thing by the passengers right foot, with a torch, you can just make it out.
Theres 3 bolts holding it down, and its a 10mm spanner to get them off. Fiddley as fuck with the dash in, but do-able! :p
cheers .. well whole dash will have to be replaced so best do that first! haha thanks for all replys all :)
The PM I sent you is very helpful.
Post it up here then, so other people can see it, too?! :)
Will do so now
This helpful info is courtesy of Olly Bartlett (Polo_6n2_g40)
alright Indy,
yea can be done in a day easily but will warn you now it is a pretty involved job. i've done a couple now.
first thing is to remove the centre console (geastick and handbrake surround) along with heater panel
next is the glovebox and panel under the steering wheel
you'll need to remove the clocks and surround
remove stereo and cubby hole
also the way this dash is designed means you're best off removing the steernig wheel and stalks
you'll need to unbolt the fusebox from the lower dash
the 6n2 has alot of loom behind the dash which is cable tied to the frame, snip all these off to free up the loom
unplug the hazard light / head light + adjuster etc
nw remove all the torx bolts from inside not forgetting one on each end of the dash where the door shuts and 2 x 10mm nuts that are through two small holes behind where the clocks sit.
that should be most of the inside done.
now open the bonnet, remove the wipers and plastic scuttle panel ( you may need to remove the wiper linkage too) and across the bulkhead under the wind screen are 4 or 5 x 13mm bolts that need to be removed.
once all these are out it should become loose and you can start to pull it away inside and see if there's anything else holding it, the heater vent ducts should pop off, before you pull it too far there is 2 wires that plug into that little sensor at the top centre of the dash in the middle of the screen demister vents.
once thats unclipped you should be about ready to pull it free, there's usually something caught or that requires a bit of a wiggle.
remember when fitting the new dash to plug those two wires into the sensor bfore you put it back in place.
you will see that there really are alot of bits and torx that need removing but as long as you work through it logically it's not too bad.
Olly
I think Indy's wins! That's a really good write up, I'll be needing it this winter anyway.
Did someone say "conversion?" :ninja:
alryt all thought i'd inform u.. me and mate had ago today we had old dash out and new one back in within 3 hours! not bad for first dash board done on a vw I've doen one on my astra mk3 before lol.. and took 2 out astra and calibra before but second dash ever put back in! found it not bad between 2 of us! .. um post above says 4 bolts in bulk head.. we found it was 8! lol hope this helps and cheers for you are help all ... airbag light still on thou.. gunna get it plugged in
