Mk2 Polo saloon crash repair
Basically, my mates crashed into the back of something and its ruined the front panel, lights, grill, wing, bonnet, bumper etc.
I'm looking for anyone who knows, what else may it have ruined e.g. weak points in the chasis leg and where to look for these?
Also if someone could tell me roughly how long it takes to unpick the old front panel and replace with a new one?
james
  • Views 993
It'll need to be inspected by someone who knows what they're doing. Panels aren't cheap and plentiful for these anymore,you may be looking at a write-off.
I work at a bodyshop, and you'd be suprised the amount of additional things needing to be replaced on what appears to be a simple 'front-ender'.
I'd be looking at the lower radiator support, radiator and cowling, radiator air deflectors, bonnet hinges, wiring loom, and thats before strip down.
I'd be wary of the A-pillars having bowed outwards too, as with front end impacts the early Polos are prone to sending the shock from the impact along the chassis legs and up the A-pillars. Also look at the nearside chassis leg end too, just ahead of the gearbox mount. Theres an almost triangular cut-out on the bottom of the chassis leg that forms a weak spot, as its a crumple zone, and might well have done just that.
