Doors and mirrors, 6N-6N2
In simple terms will doors from 6N Polos fit 6N2s? If yes are there any issues I need to know about. Trim mouldings/doorcards that kind of thing.
Next will 6N mirrors fit onto 6N2 doors? I know that the plugs are different, and I know that the caps are a different shape, but is the backplate the same, or if it's shaped for the cap is it the same overall shape as a 6N2 backplate and will it fit on the 6N2 door? Cheers in advance.
  • Views 2.9k
No one knows then? Amazing.
You won't get far with an attitude like that mate ;)
Not sure about the doors, but the mirrors definitely fit. I've got a set of 6n2 stubby mirrors on my 6n. I just had to swap the connectors with 6n connectors and do a bit of rewiring.
To be fair, prior to bumping with a little sarcasm, I wasn't getting very far sitting waiting patiently either though was I? :-D
Thanks for the answer, Much appreciated.
Some bugger's just reversed back into my son's 6N2 drivers door. :shock::-( Apparently couldn't see through mirrors or windows for ice!? :x So the question still remains! My local breakers yard has got a 1998 door. Does it fit? Can anybody please advise? 6N door to 6N2 anybody?? :-D
Regards
Regards
As a temp to keep a 6N2 salvage car waterproof, I've hung a 6N drivers door, so they defo fit, not sure if all the gumph will swap over easily though, but I suspect it will.
