advice please :D
hi i have just bought some yellow hammerite paint today to paint my brake calipers, i am just wondering is there any prep i have to do other then use a wire brush before painting? the tin says i can use the hammerite straight onto the rust so will it be fine?
  • Views 861
if you want to do a good job you should really take your calipers off and have them sandblasted or similar.
but if not at least wire brush the lose stuff off and degrease. the rust on your calipers will most likely be lose and flakey so new paint would just fall off
what will be good to degrease the calipers?
Degreaser?? Lol
Brake & clutch spray cleaner
