Bonnet Rusting
Hi I have a 6n and I want do to a kind of rat/dub look to it. I want to spray the bonnet primer grey then make parts of the bonnet rust.
Do I have to bare some areas of the bonnet down, then let it rust?
And is there there any treatment to stop the rust when I get the right amount of rust I want?
Cheers to any advice given.
  • Replies 10
  • Views 1.7k
Personally if were to do itid sand the bits back you want to rust first they need to go to bare metal then let it rust then primer the bonnet and then by laquering it it wil stop the rust occuring more
Cheers and just one last question. Is there any way to make it rust faster? e.g. Salt water on the bare metal
mix salt and water in a spray bottle and use that, that speeds up the rusting
salt water vineger lemon juice piss on it(works well) bird shit is also quite efective. i left mine in the back cgarden for 6 months and it had all that treatment.
Haha cheers i might keep that in mind
piss is the best
use a paint stripper I reckon.. or a power sander as it will remove all the coating alot quicker. then (wearing a mask) spray it all over with loads of hydrogen peroxide!! then cover it in salt whilst its wet ;) along with leaving it to get rained on.. pissing on it etc this should see it rusty right quick
Fella I know used brick acid on his passat bonnet, worked really well
Paint stripper, sanding paper and salt water :D
Just throw it on a camp fire,fetch it next morning. Put it on the car and it'll mature nicely.
