Help with "touching up" powdercoated wheels :s
The powdercoating on a small area of one of my bbs rj's suffered a scuff and has chipped the coating :-(
Would it be enough just to sand down, primer, spray ? The lip itself is very thin so i assumed filling it would be awkward...Advice would be apeaciated!
I'm not expert, but surely if you sprayed it it would look different to the powdercoat?, even if you did a good colour match
Maybe in a small area it wouldn't show that bad
It aint gona look perfect..but i can only work with what i've got unfortunatly.
touch it up with some solid paint, that is closest paint to powdercoat
by touching up i mean with a touch up brush, don't spray it, will make a mess of it
Edited by tahittiblue
By "solid paint" you mean ?? (sorry not very good in this department)
Edited by OLOP 1L
it is a kind of paint used when painting through a gun
solid paint = non metallic.
:thumbsup:
