what is this vent in the rear quater panel?
Hi guys.
1997 1.4 8v
Mine has developed a leak somewhere in the boot. When I peeled back the trim from behind the rear lights I saw something that resembles a black plastic vent on the side of the car. Its positioned near to the fuel filler cap but on the inside of the rear quater panel.
What does it do? It looks to me like the water is getting in here from the rear wheel arch. Would there be any problem if i sealed the vent up?
Russ
  • Views 1.6k
don't seal it up
its for when you shut the door the pressure inside car is released through the vent or something like that
don't seal it up
So the cabin doesn't pressurise when the blowers are on .
don't seal it up
Or for when you slam the door, the windows don't pop out
don't seal it up
lol, as if them blowers are capable of pressuring it!?!
As already said.
don't seal it up
Well it sucks air in doesn't it? So a small leak is needed to allow for the extra air being blown in. Honestly, this is one of the reasons.
cheers guys
I did not think of that.
Would this be the likely cause of the leak? I can't seem to find anywhere else to be the source
rear lights is usually were it will leak
