Carpet change
Hi... I was fancying changing the carpet to red in my 6n... like the old 205 GTI's used to have.
I was just wondering if anyone's shaped carpet like this before?
panda.
  • Replies 10
  • Views 1.5k
Bit of a specialist tools and tricks job unfortunately if you want it molded to shape. I've recarpetted cars with flat carpet before, it's ok if you've got a lot of patience, contact adhesive, and are very good with a stanley knife. A deeper pile carpet (eg acoustic) is the way to go if you're doing it this way as it hides the joins.
Could you not vinyl dye it?
Gonna say, doesn't the L spec 6Ns use White/cream carpets that could be dyed?
hmm... could be a good idea... wonder if it'll dye OK? I want a really bright red, never seen it on a polo before.
No don't use that it is crap - I tried using similar stuff to dye my Headlining and turned out nasty.
I would just spray it with Fabric paint (24quid PER can) using decent paint. But I used Plastic Spray Paint Satin Black for my Headlining and it looks mint.
If your Carpet is the lighter Grey then you should be OK but if the Darker grey then getting it Red may take a fair few cans and may not come out with the right colour you expected.
Edited by haz911
i carpeted my car DIY style and if I'm honest it came out quite well for a bodge, I'm sure if you was going to use a thin carpet then maybe it will be easier to bump over and get it all right my carpet is basicly... Living room carpet the front came out very well the back i need to glue down and it should look mint :D as soon as i saw the offcut of carpet i had to try it :') its a far from professional job but
i would think maybe you could bleach the colour from the old grey 8v carpet and then soak it in a tub of red dye?
Hi... I was fancying changing the carpet to red... like the old 205 GTI's used to have.
x2 but for the pre-'94 floor pan.
Panda, it might be worth looking at the shape and size of other floorpans - its possible that a 309 GTi carpet could be persuaded to fit better than a flat carpet? I'm gonna look at the 106 floor i think,surely there are more manufacturers that did it.
Newton Commercial sell new carpet sets for the MK1 Golf afaik but i dont know how well that floor pan is related to the 6n? Could be close! They'd make one any colour you want,but it wouldn't be cheap.
I have...
who's is that?!
Mine... Done it yesterday when I got home.
Jokes, trottagtis
