polo gti fog lights
Hi all, I'm new to the forum, i am picking up a polo gti 2000 model on saturday, its got a broken spot light, is it an easy job to do, also is there any thing i should look for when i go to get it? Its done 92000 miles, five door silver, and its £1900 is this a good price?
thanks.
  • Replies 8
  • Views 1.4k
You'll need the front bumper off to replace the spot lamp. Its not a hard job to do, you'll just need a torx drive screwdriver in addition to your standard toolkit.
I didnt think the bumper would have to come off!
I've done it before without removing the bumper.
Is it easy then?
I was under the impresion the foglamps were screwed into the rear of the front bumper? My bad!
Hey, I'm also fitting front fogs soon, was just searching the forum about fitting them and found this, hope it helps
I have recently done mine! It's piss easy! When you remove the front grills you reach in and there will be a wore secured on a clip, detach it and it plugs straight into the back of the foglight! When I fitted mine I used some stud wall fasteners, so as you tighten the screw forces the clips to push out and keep it held tight! And removing the switch! Push the knob in, and turn to the sidelights position, and pull, then detach the cables and then replace the new one exactly the same!
Hope it helps
Hi, seems easy then does it? Just got my modified vw caddy with black audi pepperpots up for grabs on ebay to fund the gti, cant wait to get it.
1. look on the bottom left hand side grill of front bumper or right depending what side you need to change you will see a screw could be a flat head or philips
2. undo with screwdriver
3. locate cant remember if its bolts or screws but there will be 3 holding the fog light in (the bottom one closest to the centre of the car is a adjuster screw leave in)
4. undo the screws/bolts fog will come out just unplug and plug new one in
5. do back up in reverse order as stated above
should take no longer than 5 mins
:thumbsup:
Edited by rtuk
