Looking at a 1l MK3 Coupe
Soooo, my Golf is too much to insure, looking at a 1l Coupe because the insurance is mega cheap. Also, my older brother had a 1.3 for his first car and I miss it. :(
It will most likely be a 1l unless I can push to a 1.3 because it would be nice tbh.
The 4 speed box will just annoy me. Is that all the 1l's come in? If so, will a 1.3 5 speed fit? Because I will burn my clutch out in the end so I have reason to put a 5 speed on.
Common problems and things to look out for?
Brake upgrades easy enough?
Cheers for all this, getting WAY too excited about it, went from a "cheap crap around" til I can afford my first car to looking at threads on here and falling in love. :lol:
Cheers! :D
  • Views 1.3k
Can indeed fit a 5spd box on a 1ltr
Have to change the mounts and some other stuff though i think (someone on here will know)
tbh, i bet theres bugger all difference in insurance between 1.0 and 1.3
My insurance didnt change from a 1.3spi to a 1.3GT and theres a bigger difference in power between them 2 than there is 1.0 and 1.3
Rusty battery tray
Whining 5th gear
rusty fuel tank filler neck (can leak petrol savagely)
Brakes are simple to upgrade, can go from solid to vented discs by using VW11 calipers (G40/MK1 golf Gti calipers)
of those comon faults i've had 2, and thats because i dont have the 5th gear...
If the brakes work as they should, they're pretty good! I used to cart loads of heavy stuff in mine, and never had an issue with the brakes. It was the lack of traction that annoyed me (and "broke" the car in the end!)
I'd look into insurance on 1l and 1.3... as above, there may be very little difference, and the 1.3 would be so much better! I'm under the impression there's nothing in it in terms of economy, and you're not pushing the 1.3 as hard to get anywhere, so less likely to have head gasket related trouble.
At the time, I never felt that a 5 speed'd really help the car much with a 1l - the 5th would be a bit higher than the 4th, but then you'd have absolutely NO power whatsoever in top gear... Mine happily went up and down motorways with a 4 speed 'box.
I reckon the best upgrade for a mk3 is decent seats - a pair of scirocco or corrado seats are money well spent! ... other than that, (and stiffening up the suspension, so hopefully it'll handle... a bit) I'd just go down the route of making sure everything's maintained well, and works as it should. They're a pretty good car then! ... and NEVER put budget tyres on!!!
I put wider wheels under mine (going up to 165 tyres) .. not a lot, but made a mighty difference to the grip.
As for stuff to look out for - everything already mentioned, plus wet carpets. they can be nightmares to find leaks on... and the leaks can be a nightmare to fix! Mine was never right till i got the windscreen removed, and replaced with a new seal.
Main faults are rust - pretty much anywhere if it's a light colour, but back of sills, valances, battery tray, exhaust hangers, and round the windows.
Check for smeg in the oil and oil in the water, and bubbling in the coolant when running/just turned off - signs of head gasket failure.
Waterleaks around the thermostat housing.
Not restarting when warm (although can be very intermittant) - hall sender failure
Erratic idling.
do you??? ( i didnt ion my old mk3 1l when my 4spbox went bang just got myself a 5spbox and bolted it straight in lol)
Erratic idling.
Cheers.
I'm a mechanic by trade (well aprentice for a couple of years) so I'll be extremely anal.
But yeah cheers for that, give me a list of things to look at.
The difference in insurance is £500 between a 1 and a 1.3 I'm found out, it's rediculous.
Ah well, I'm hoping to set it up like a go kart tbh, was thinking of a 60mm kit but the coilovers on my Golf are well handy.
I've never done it so I'm not 100% But its what I've read on here
Maybe the gearbox you had already had the mount on? Its the top mount thats different, bottom is the same.
