mk4 golf recaros
a friend of mine wants to swap his mk4 golf recaros for a set of black leathers out of a passat i have lying around. I'm pretty sure i need to modify the front mounts on the front seats to get them to fit but not sure with the rear seats, is it just a case of swapping the metal backrests for the polo ones or is it more complecated than that?
  • Views 941
which polo are you fitting them to?
ahh sorry forget that bit. its a 6n
mk4 golf will not be a straight fit into a 6n I'm afraid.
yea i know thats why I'm asking what needs to be done, I'm pretty sure whats needed on the fronts to make them fit, but need to know if the rear backrests are as easy to fit as the mk3 golf seats ( swap the metal backplates around) and how the bit you sit on is fixed to the car
