mk2 polo dash removal
trying to sort out my screaming speedo drive so i guess the dash has to come off.
is it a hard job to do or is there an easy way to get to the speedo drive?
tried searching the forum with no luck if there is a link then i shall take it and run with my tale between my legs :wink:
  • Views 4.4k
You can just remove the clocks. There's just a few screws, and you need to pull and jiggle it a bit
Yeah,two screws for the pod switch panel,unplug the switches as you draw it out. Steering wheel might get in the way,might wanna remove it. Pod itself is another two screws,lens tilts downward for easy way out once you've unplugged the speedo drive,if you need it out. Speedo plug is pulled out with a little catch on its side pressed with your thumb/finger. Bit fiddly but easy enough.
thanks very much chaps was being driven mad by the sound
