51mm throttle bodies are back - G40!
Ok. Here we go!
Over the last few months I have been sapping up throttle bodies for sale.
I spent this weekend in our machine shop calculating butterflies because thats the most important bit of the whole throttle body. we calculated the chamfered edge and made a jig to be able to make the 51mm butterfly with chamfered edges (for best seal) I'm testing a 45mm one in a standard body at the moment and it hasn't stuck or hunted revs yet. works real sweet. (much better than my riveted de-wedge and much much better than the standard wedged body i just took off)
So in the next few weeks (maybe this week) we will be making a 51mm to test. I have also got the top t-peice ported to match the 51mm opening and ported + polished the rest.
Photo's of the test:
I really wanted to make something to almost OEM spec and our 45mm test butterfly seals excellently!
Going to road test the 51mm when we get them going shortly.
So our units will consist of:
Ported & Matched t-peice.
51mm butterfly with chamfered edge.
New gasket between t-peice and main unit (i want to add a tiny lick'o sealant because of the smaller size (cut to match)
Price will be £150 exchange
Contact me if you have any questions.
  • Views 1.9k
Good stuff!!
8-)
So would this be a straight swap over?
Let me know on the test results. Very well interested..
Yeah direct swap mate
Is the price exchange, or outright purchase?
Any work done on the spindles?
And what material is the butterflies made out of?
Mark
Mark
Thats the exchange prices - G40 throttle bodies are pretty rare and hard to source!
You do need to modify the spindle to accept the larger butterfly yes, we have a method for doing this too. Butterflies are aluminium!
You going to let us know about what sort of figures it gives
once i got them testing I will do
