hids4u.co.uk discount
Was just about to buy some HiD's from www.hids4u.co.uk and noticed there was a discount code box! Did a quick search on google and found this:
For those purchasing a ultimate kit should use the voucher code: Toyota one
And for those purchasing a pro kit can use the voucher code: Toyota Pro
Even though the post i found it in was from 2008(!) it still worked!! I just ordered the 55w pro kit and got £33 quid off!!
So if you're about to order some HiD's check them out!!
(original post here -> www.uk-mkivs.net/forums/p/180850/1183972.aspx )
Dont know whats up with the links but if you copy and paste them into your browser address bar they work!! :)
Edited by dansharpy
  • Replies 12
  • Views 2.8k
not nocking these guys but there is a place ner me that sells extremely good ( slimline hi/lo beam kits ) kits for around £75 ( not £135 i just got quoted by them )
Edited by vw2vr6
I did put another post earlier this week asking for recommendations as i didnt have a clue! This was the only recommendation i got so i went for them!! They also have a good warranty which i like, seeing as i dont have a clue what constitutes a good/bad kit!!
If you use the codes above then the £135 kit you looked at is only £105, which i dont think is bad for that sort of warranty, and its a 55w kit!! 8-)
The warranty is good but you probably won't even need it. I got my kit from hids4u in mid 2007 and it's still going strong, not even had to change a bulb.
You get what you pay for :thumbsup:
bloke at work did the whole cheapo ebay thing/hong kong etc, lasted about 2 weeks before having problems.
and yes they were fitted properly, before anyone starts saying 'he must be retarded and fucked them up himself etc' :)
i did the whole cheapo ebay thing/hong kong, have lasted me 3 years without any problems...
Got the kit through yesterday, fitted last night (in the dark!!) Was sooooo easy to fit!! Literally plug and play!! No extra +'vs or -'vs to wire up, just plug the existing halogen plug into the one on the new harness, plug the new bulb harness into the ballast and you're done!! :) Hardest part was mounting the ballasts, still managed to do it even though they were not slim ones.
Will post pics in a bit..... :)
Pics:
Ballast mounting:
Before:
After:
Comparison of new versus old:
We'll have to see the difference at night later on my way home from work!! 8-)
am I the only person that thinks these are really a-social?
Refracted lenses arent supposed to have HID bulbs behind them (which is the main reason why it blinds everyone coming your direction).
I wish folks would just spend the money on getting proper ones that dont blind oncoming traffic :(
If adjusted properly they dont dazzle people coming the other way.
I put 7 pin headlights in for that very reason, so even if i have more weight in the back of the car i can adjust them down so they still dont dazzle oncoming traffic.
The ones i just fitted have bulb shrouds so the beam is only directed out of the bottom of the lens, this means even if they are refracted it is still not into the eyeline of oncoming traffic.
Mine don't blind oncoming traffic.
Projectors aren't compulsory for Xenons, there's many standard cars with Xenons which don't have projectors. Renault, Honda etc.
I fail to see how spending 140 quid on a hid conversion kit is not done properly!
I could understand if it was an eBay job not totalling more than 40 quid but in reference to the opening post this sounds ridiculous
I assume Rin is talking about buying projector head lights as well as the HIDs...
