Taking down roof lining
Just wondering if anyone knows how to take the roof lining down as i don't have a clue, and i am aftera new roof lining. i have searched for guides but can't find any.
cheers
gazz
  • Views 966
pretty easy man, take out all the fittings (grab handles sun visors etc) then the pillars, which i pulled off but do them carefully as the clips break quite easily. Then after you've done all that it should just fall down. Just go out and have a go, worse case scenario is that you roll around with no roof lining for a while. We've all done it...
yeah as above, it may be glued to some sound proofing in which case just run your hand between the roof and lining or use a ruler and it will come away, worst off with some creases but you can get them back out with a little heat.... irons are good but make sure you use a tea towel inbetween! :)
aye cheers guys ill have a go post some updates soon
