MY MOT FAILED TODAY
took my car for its mot and it failed i was worrying about the cat and exhaust and it turns out that was not the probleme
not sure what there are help will be gratefull
1. suspension arm bush
2. excessive movement in macpherson strut in the upper support
3. excessive movement in macpherson strut in the upper support bearing
not sure how much it will cost to fix??
thnks
  • Replies 10
  • Views 2.1k
thnks
can you give details of the car and model year etc mate it will help people to evaluate the cost of materials they are pretty common things on most polos and parts are readilly available it shouldnt cost too much to have repaired
i forgot to say its a 1996 volkswagen polo 1.0 hope this helps
complete new strut on one side and dont know if its cheaper to buy a wishbone rather than bush and pay labour for them to press it in
are you doing work yourself
no I'm not got a mate mercanic
garages in dundee charge on average 35 an hour labour so 1 hour labour plus parts plus vat, the strut top mount and bearing can prob be bought relativly cheap...
europarts online quote £8 for top mount and bushes around a tenner
50 for mot and parts and labour shouldnt be much more than 100
maybe someone of this site local to you can do work for cheap
what parts are needed please help
suspension arm bush, cheaper and easier to buy a whole arm from GSF
and the macpherson thing is more commonly called a "top mount"
Top mount and wishbone, haven't looked but I'd guess about £30 all in from here www.vwspares.co.uk
1 hour labour, 2 at a push. Done within the retest period, so £100 absolute tops I would think.
so i need
top mount
and a pair of wishbones??
if need be just take your mot fail sheet to gsf!
they can see what you need then, it should say on the sheet which side is needed etc
