how do i get the sideskirts of of my polo mk 5 6n2?
i need some help on how to remove the sideskirts please?
  • Replies 11
  • Views 2.1k
Are they not part of the sill?
i dno but i seen that the gti ones are different so thought that they must be able to be changed?
afaik the sills are different on gti models
They're welded on though, so it's not as easy as bolt off bolt on.
I think I read on here the TDI and 16v skirts are the same as the GTI ones?
so can they not be changed?
They can, I've seen a 6N on here with GTI skirts.
Just a fair bit of work involved. Cutting and welding etc
alot of work doing it. i'll let you's know sure ;)
Yep, Dom's 6n valver has gti sills.
Its a lot of work. Id say its only worth it if your normal sills are fucked and they have to be replaced anyways.
oryt okay gys chears :) thanks for helpin me x
Front wings are different aswel, so they'd need changing.
