fitting mk4 golf seats to a 6n2
hey,
i relise that only a mk3 golf interior or a 6n interior fit the 6n2 straight off, but is there any way that the mk4 golf/bora interior can be modded to fit? like changing sub frames etc
i only ask as 6n2 seats are like hens teeth in belfast and its way to dear to get them couriered from the mainland.
cheers, chris
Edited by memsis
  • Views 3.2k
it will tak some work, but if your any good with a welding mach then its deffinatly possible.
the mk4 seats use runners which are attached to the seat and bolted to the floor.
6n2 seats have legs that slot into riunners which are part of the vehicle body.
you could either butcher your old seats , remove the legs centre runner, chop off then bits from the mk4 seats whip up some brackets and weld them on, or
create a fixed frame which would fit to the floor and allow you to bolt the mk4 seats straight to the frame.
hope this helps
no worries man. thanks! i dont have access to a welder unfortunately so i may just keep hunting for 6n2 or mk3 golf seats!! cheers for the advice :D
